Enable tag and dimension in legend view.
there is something annoying that makes many of my colleagues create a "legend" phase for just for legend purpose.
For instance, we can tag material and layers on a wall composition , but why couldn't we dimension the overall width or even tag the typeMark of the wall?
who use only material tag?
135 Comments
Tags cannot be exposed unless you have an element to tag. As a BIM manager, I want to see all my tags without bringing in useless elements in my standards file. More importantly, we want to show tags in our legends without having to manually duplicate and maintain as up to date symbols.
To achieve a proper smart BIM workflow, I propose the two following capabilities:
  • Allow us to place tags in Legend views
  • Allow us to easily maintain a relationship between tags and their respective symbols.
    • Perhaps every tag is automatically converted as a symbol or there is a functions to do so.
    • If we could place tags in legends, we would probably not really need the symbol version except for old users who still think in CAD and use symbols to hide all the CAD mistakes they did in Revit.
Just realized you can drag and drop the annotation tags in your legend Still, there should be a more natural way to place these tags into legends, like a tagging button in the Annotation tab, that lets you select the tag type when there is no object. https://forums.autodesk.com/t5/revit-architecture-forum/legend-of-tags/m-p/7835231/highlight/false#M...
simo74
It is incredible how such a basic and so important function can be ignored by Autodesk year after year.
The first update requests date back at least 7/8 years ago and nothing has been done to improve the legends
Kevin.Bell
You can't tag a family when placed in a legend - you have to use text.
Tags should work in Legends as with any other view.
dennis_collin
Absolutely, agreed.
Revit knows the name of the component in properties so it should be an easy thing to implement you'd think.
Yes I agree with this too.
we need to tag and keynoting items inside any legend or detail view
its against BIM to type data on legend as text , when some thing change in the family , its not modified in the legend it self
Kimtaurus
I found a work-around using dynamo https://forum.dynamobim.com/t/tagging-a-legend-in-revit/5444/6
It is amazing how little code is required to implement this, AutoDesk should fire a strategist and hire a coder to work on little stuff like this, they could knock out implementation of ideas like this at a rate of a couple a week (including setting up unit tests) and end up with annual releases that we look forward to rather than have to buy only because we're on subscription and can't save down.
Also I was able to extend the original idea to aggregate data from all instances and their hosts so I can tag my doors and windows on a legend sheet with a list of fire ratings of the walls they are in.
yes, thanks for your notice
but its really very big request , I don't know why autodesk not implementing that
I think we all have to stress in this similar ideas
thanks
r_evers
Lets make it possible to tag an Legend Component in Revit.
Now the Text is dumb and not connected on a legend component
Tags (3)
abowman
Observer
In order to make the Legend Tool useful it needs to be able to host Section views, specifically for Door and Window detail callouts.
Text boxes are just not BIM. Why have the possibility to drag a family as a representation in a legend when you can't tag that representation. Quite non-intuitive if you ask me.
Tags (5)
When using legend components to document your design: You cannot dimension to host components, such as walls, ceilings, and floors. This needs to be made available.
GHASEM_ARIYANI
Hello
Dimension tools work on the walls and floors layers in Legend views.
hstaabprime
Autodesk - please escalate this idea request to defcon 11.
Requesting API support for creating Legend Views and Legend Components.
This has to be the biggest overlooked development opportunity in Revit so far regarding architects at least.
And specifically door/window drawings.
Archicad seems less typebased and thus slightly better in earlier phases of a project.
As the project develops Revit pulls comfortably ahead expect on one thing.
Revit has a great type system but cannot document the types properly.
Looking at this very rationally and professionally, during the last 10 years, deciding not develop the ability to document types is just an error of jugdement. Simple as that.
You have Assemblies but those are unusable for Door/Window drawings for a number of reasons.
(One being they disappear when the last instance is removed)
Legend components is the logical choice but you cannot tag the information they have.
So the core of the issue is to create type drawings incl type data.
Seems so obvious right ?
Except using Revit you cannot do it.
Archicad can do it and is very very good at it.
Putting a normal Door tag on a Door component in a legend view seems to be one logical path forward.
Creating Assemblies directly from a type (no instance involved) could also do it i suppose.
But seriously come on, something needs to happen here.
Tags (2)
Just want to add some more information to my original post here.
Here is a few examples on whats needed from electrical and architectural.
All disciplines need it in some way.
Example using Lines, Legend Components and Text.
(It could have been just one Tag getting the information.)
Then you might say.."hey what i minute we can do that with the Type Image parameter in a schedule".
We tried that and even made a function to update those images.
But its not usable because you cant align the text vertically to the image. (vertical middle)
This is how a Revit schedule will look today with the Type Image parameter:
Then you have architects who needs Door/Window Drawings.
Which can look like this but can have numerous layouts.
(Which a Door Tag will solve)
Again - this could be a Door Tag - just let us tag it.
We have been using secondary design options sometimes to make those.
Design Option because you can use tags.
Secondary because they dont show in regular schedule quanitites.
So another idea is to make the "secondary design option functionality" available as something else.
Like a category-specific virtual design / documentation space with an API that to support it.
(Currently there is no API support for Design Options.)
This is low hanging fruits with large benefits.
More or less use what you have with some changes.
So all in all four ideas that will get us closer to doing this:
1. Standard category tags in legend views.
2. Create Assemblys directly from Type geometry. (No instance involved)
3. Vertically align text in a schedule (wont solve everything but its a good start)
4. Secondary design option-ish documentation space incl API support.
