Electrical Design Analysis - Single phase option
Adding the ability to select "Number of Phases" in the Properties Palette for the Electrical Design Analysis Tool for Revit '23 and newer.
While trying to use the Electrical Design Analytical tool within Revit '23, when entering our electrical loads for calculations they are all locked/greyed out on 3 phase power in the Properties Palette with no option that I see how to change between a 3 phase or a single phase power source.   Ex. If you enter a 120 Volt load it is always locked at 3 phase causing the calculations to be wrong, instead it would need be 120 V single phase load.
1 Comment
npetersonKE23D
It would also be nice to be able to type in the System Browser or a Revit schedule instead of having to go to the Properties Palette to make these changes.
