Edit view range of multiple Plan Regions simultaneously
I would find it quite convenient if I could select multiple Plan Regions within a single view and be able to edit their view ranges to have the same values in one command. This would be simple: the user would select all Plan Regions which the user desires to change, then they would go to the Properties panel and click "Edit" in the View Range property, fill in the desired values, then click "OK," and all selected Plan Regions would have their values set to what was entered.
An example of when this would be useful occurred when I worked on townhouses which were terraced, each unit at a different grade height than those on either side. Plan Regions were crucial in creating the overall building's floor plans, though setting them up became tedious and repetitive. Even though the Levels were different for each building, it would nonetheless expedite the process if I could set the Top, Cut plane, Bottom and View Depth's numbers in one command for multiple Plan Regions.
