Drafting Views as option for Linked View
It would be really great if drafting views from a linked model were available as options for the linked view. This way details and other 2D drawings could be available across shared models from one central project. Also a good option as a workaround for a legend that could be shared with different models and would update live when the link is reloaded
36 Comments
Dan.JohnsonW9TVQ
This should be basic functionality and something Autocad already does. Why doesn't Revit already do this?
acrossonbouwers
Funny enough, bicycle manufacturers actually don’t include pedals with most bikes – not to take away from your point though, just a funny anecdote 😊
One more up-vote for something that may never come to pass 🙂 This would be a great way to manage file sizes.
AndycMacp
Any joy with this?
waldie.jonathan
Thumbs up to implementing this idea.
Dan.JohnsonW9TVQ
Also, perhaps a good idea for large projects where one consultant or stakeholder has more than one model. ie. typical details, typical notes could be linked from a company or division container file without having to bog down your main model with so much typical stuff that may not be editable anyways? Sometimes we split models along expansion joint lines or if there are many buildings in a project, keep them in separate models to keep file size down. Just another way to organize and keep things simple. Or complicated depending if you are glass half full or empty type person. 🙂
gdunhamPY2ED
2023 and still nothing. My search continues...
AndycMacp
It's mad this is not a basic functionality. A workaround I use is a regular plan view in the base file, with all the model components turned off and only the annotation layers turned on. You can then use this as a drafting view and link it into another file/files. This will mean the linked views will all update when you update the annotations in the base file. I'm sure this is not perfect!
JakeLape
Observer
The ability to Revit link in Drafting views from one project to another could be beneficial. It allows us to maintain one main project for all details that is the "Master Detail" Project and will allow us to be able to update and reload whenever there are changes in the details. This way details do not have to be replaced on the sheets rather just updating in their respective locations in the projects.
ChrisGamble
Still looking for this to be implemented one day.
m_barnett
m_barnett
johnericsons
8 years later and still not available
kadenk3AKS5
Adding my vote in hopes this happens at some point in the future. It would be fantastic to have the [Visibility Graphics - Revit Links - By Linked View] functionality available for drafting views! That would save incredibly amounts of time and workarounds for all companies keeping a "Typical Details Library".
Vote Vote Vote!
MWM_EltiB
I remember voting for this years ago. Hopefully will be available.
kadenk3AKS5
Commenting again in hopes to keep this alive. Simply having a "By Linked View" from Drafting View to Drafting View between projects would be a MASSIVE time saver. Everyone who uses any kind of typical details created in Revit is already keeping a Revit Details File or pulling from the last file they used it. It would be fantastic to just have the ability to Link from that, rather than insert from it. Inserting makes management of any typical detail updates incredibly tedious and prone to error without the use of Dynamo or Custom Extensions.
