Don't print - area boundary
Hey, it will be nice if we could not print area boundy.
6 Comments
jbrr27
This is a good idea, as long as it comes with an obvious toggle switch like unreferenced sections and crop boxes have.
►BIM-Roman◄
@jbrr27  i added a screenshot with example like you mention.
Mike.FORM
Are you asking about boundary lines for Areas? (see image)
Or for adding a boundary to indicate a printable area? How is this different from a crop boundary?
or for adding a boundary to indicate a printable area?
►BIM-Roman◄
My request pertains to the area boundary line for the designated area. It would be beneficial if we could work with the area boundary line & area in marketing or permit plans and print it without the boundary line, only showing the geometry and color scheme:
Mike.FORM
You could somewhat accomplish this by making a line pattern containing just a dot and a very long space and the set that in the override in that view as well as the colour to white. However this is a bit of a workaround and is not as simple.
If we could just have non-plotting line styles, that would fix this as well as allow us to have guide lines. Currently, I use white lines. But they will print white, which is not always desired when they lie on top of other objects.
