Divide walls/floors structure layers into other walls/floors, preserving the category
I would like to divide the layers of the wall structure into other walls. You can work the coatings independently. It would be interesting if each structure layer could be transformed into a wall type. Similarly for floors
Gostaria de dividir as camadas da estrutura da parede em outras paredes. Para pode trabalhar os revestimentos de forma independente. Seria interessante se cada camada da estrutura pudesse ser transformada em um tipo de parede.
Analogamente para pisos
2 Comments
Hi, @Anonymous ,
Here is a similar topic. Do you think it would be ok to combine them?
Wall explode - Autodesk Community
-Kimberly
YarUnderoaker
I have an idea about walls which can be compatible with this idea.
Invite to vote New elements class - assembled wall
