Divide ''select links'' [active or not] button into Revit,IFC etc links AND AUTOCAD separately
During coordination process, I often have to do synthesis between a few Revit linked models vs 1-2 DWG files. I wish I was able to select DWG only files and other 3D objects in the model, all while leaving the 3D linked revit/ifc models locked with the ''don't select links''.
And no, getting the Revit files on LOCKED, deactivating the selection of locked elements doesn't work. As I want the DWG to be locked as well, but selectable.
