Display File Description from ACC in the Autodesk Docs file menu within Revit
A lot of countries have to follow strict file-naming conventions, with codes, rather than descriptive names. The codes in file names typically only vary slightly, which can make it hard to immediately identify different files.
By displaying the Description field, which is already available in ACC, within Revit, it would enable us to clarify the model contents in text, without adding it to the file name, and make it easier to differentiate between files.
