Disallow Beam Join - multiple beams (metal panels)
Wishlist:  I want to select a group of beams and then disallow beam joins for all of them at once.  Or, before placing a beam, or beam system be able to pre-select disallow beam joins for all beams about to be placed.
Here is where I use this most:  It took me several attempts to figure out how to add 3D metal siding to a structure (industrial process facility settings), but finally I stumbled on a method.  I built a typical 36" wide sheet of metal siding as a beam (a line based extrusion), for which I can then create any siding profile/width I want.  Next, I place a work-plane along the outside of a framing line and name it "____ Siding line".  Then I go into an elevation of that side, set the work-plane to "____ Siding Line", and place a beam system of the 36" wide siding "beams" at 36" intervals and voila, I just covered the side of the structure with a series of accurately modeled 3D metal panels.  I have only two problems with this method - The beam ends want to join with nearby beams, and I have to go back and cut the edges off - if the siding wall isn't rectangular.
Alternately, a 3D panel/siding/decking tool would be fantastic, and could be scheduled or taken all the way to fabrication level fairly easily.  With the beam system approach I can almost schedule decking/siding now.
3 Comments
lionel.kai
Your WORKAROUND seems like a lot of WORK. 🙂 Although it might be worth it if you can (and need to) schedule out the siding and/or make shop drawings?
Instead, here is an idea to solve the originating issue - creating walls with a metal siding profile:
http://forums.autodesk.com/t5/revit-ideas/quot-structural-deck-quot-layer-for-roofs-and-walls/idi-p/...
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
Status changed to: Archived
