It has been observed that while loading any window family in a Revit project we can't change the base level height after given value in to Default Sill Height parameter from Type Properties DB. Whereas it will work fine when change the value [Sill Height parameter] from the Window Instance properties DB.
But the Default Sill Height parameter will work in the family interface.
Mainly we want to change the Sill Height parameter as a Type parameter instead of Instance parameter.
Relevant Snap:
Autodesk Case ID: 13332678
Subject: Difference between Revit Default Sill Height & Sill Height
