Allow dimension lines to read Rough Width / Height parameters of doors/ windows
Idea logged by Autodesk Customer Support for German customer Ladislaus Wichert:
When dimensioning a wall, wall openings can be included in the dimension line with the openings height and width parameter.
Doors and windows have however more parameters related to their dimensions. There are rough height and width parameters in window/door families in order to specify raw building dimensions of the construction.
Please, enable Revit users to specify which parameters should be read by the dimension lines regarding wall openings.
Please, also enable to display those dimensions with a prefix or suffix.
10 Comments
lukas-tunka
It will be great to have a possibility to add the sill height parameter into the dimension, to see the window offset from a floor level.
m.i.m.o
PLEASE
Fabian.OswaldS52TK
Dies wäre mehr als hilfreich, die Parameter Rohbauhöhe / -breite und Höhe / Breite sind ja immer vorhanden.
PXG_RB
Observer
How long does it takes yet? We still need a solution ...
Mouamen.Hafez
Community Visitor
we are still waiting 😞
vdaskalov
This should be important.
Daniel.Elbers
This would be really helpfull!
a.weberUPXQC
This is so important!
TasirNafas
Observer
Any Solution?
wr.marshall
Nice idea vote for!!!
There is issue though whereby most users want window referenced from head height as apposed to the current methodology of sill height as discussed in this idea
Make window head heights consistent - Autodesk Community
in order to make plan same as elevation same as schedule dimension needs to allow use of custom parameters unless they resolve the issue in the link
-EDIT-
This is relation to this part of the idea by @lukas-tunka showing the sill level, head level and  height in the floor plan dimension.
