Custom leader arrowhead
Please, I hope can custome leader arrowhead. So we can more creative.
70 Comments
erikreed
Would love to have custom arrow heads. This needs to be added.
jwverde
Definitely need a custom arrow head!
Joel Westervelt AIA Architect
JamesMcKinnon
I don't understand why this is not already in Revit. Especially given that Autodesk has had this thread linked from their knowledge base page on arrowheads: Here.
WEIxxulc
We need this feature to increase the aesthetics and creativity of the drawings,please!
I need to add a cross target symbol without a circle around it to my project per our office standard.
THANGGG
it sucks if we are not able to do what we want in general. let's be able to create custom arrowhead like we create family when needed.
PDStudios
I am not exactly sure why this wasn't part of REVIT 1901, (0.0), or whatever naming conventions are appropriate but it is LOOOOONNNGGG overdue!
Nate.Ritta
For real autodesk... get your $#!7 together
spowell
In Arrowhead Settings, can we have the option for a heavy end Open Arrowhead? Just the Arrowhead and with adjustable angle, please!
thanks 🙂
Tags (1)
wr.marshall
This is already on the software
Arrow width Angle adjusts the angle & no tick in arrow closed has an open end. If this is not what you are after more explanation required.
@spowell  Does @wr.marshall 's suggestion resolve your request?
rlawyer
It seems pretty sad that this very simple add is not already addressed. It is a very basic procedure. Please add this functionality... it has been being requested for 20 years.
magermanoai
@kimberly_fuhrman-jones I don't believe it does. I have the same request and I know many others do as well.
https://forums.autodesk.com/t5/revit-ideas/allow-lineweights-for-arrowheads/idi-p/6329582
The lineweight option is grayed out in @wr.marshall's response. The arrowhead defaults to whatever lineweight the leader line is set to in the project object styles, typically 1.
We can change the lineweight for the thick end arrowhead type, why not all arrowhead types?
@magermanoai  Thank you for the additional clarification!
-Kimberly
JGuptill
If AutoCAD can do it using blocks, Revit should be able to customize arrowheads customizing families.
nskok2
Observer
It's issues like this that cause so much frustration in Revit.
hhalstead
This needs to happen
Yien_Chao
hello
this should be simple. we can do it in Autocad, but why custom arrowhead still missing?
Tags (1)
Tres_Hernandez
At the firm I work for, we use just a crosshair symbol for our spot grades and while there's currently only a small list of options for arrows, I'd like it if you could open that feature up to further customization or just add one that doesn't include the circle around the elevation target. Seems like an easy thing to do and not sure why this is so locked down.
pawel
We could really use something like this:
