Control Schedule Text Alignment while a View Template is applied to the schedule
In a normal schedule view template for a schedule you can only control things like text sizes. You cannot control the alignment of the rows or columns, however when you apply a view template to a schedule, to change the alignment you need to temporarily change the View Template to none then reapply the template.
Please can you change it so the alignment options are not greyed out & controllable while a view template is applied to the schedule.
Kind Regards
David
1 Comment
clairedimond
Same for Resize column too
