In a project, I'm not able to locate rooms, using a color sheme. Here is what I see:
![Avant.PNG Avant.PNG](https://forums.autodesk.com/t5/image/serverpage/image-id/516585iCB4A6FF3C565E864/image-dimensions/457x399?v=v2)
The rooms "HYPERMARCHE" and "Réserves" are not shown with colors defined in the color scheme. However, if I disable the pattern of the slabs in the view (using "VV"), I get this result:
![Apres.PNG Apres.PNG](https://forums.autodesk.com/t5/image/serverpage/image-id/516588i623BBA57EF88BB3C/image-dimensions/460x403?v=v2)
(The color scheme works properly). The pattern of slabs under "HYPERMARCHE" and "Réserves" (Uniform/White : see below) seems to "override" the scheme color, and I would appreciate if it won't.
![motif_sol.PNG motif_sol.PNG](https://forums.autodesk.com/t5/image/serverpage/image-id/516591iA846C9B07BF32801/image-dimensions/380x58?v=v2)
Thank you in advance.
Sincerely.
Thibault Masson
