Color Scheme overridden by slab pattern
In a project, I'm not able to locate rooms, using a color sheme. Here is what I see:
The rooms "HYPERMARCHE" and "Réserves" are not shown with colors defined in the color scheme. However, if I disable the pattern of the slabs in the view (using "VV"), I get this result:
(The color scheme works properly). The pattern of slabs under "HYPERMARCHE" and "Réserves" (Uniform/White : see below) seems to "override" the scheme color, and I would appreciate if it won't.
Thank you in advance.
Sincerely.
Thibault Masson
