材质面板参数不够用
材质面板参数不够用
也许revit的计算工程量的方式更偏向于模型构建,但在实际运用中有些场景是以材质面积作为主要核算依据的例如室内装饰。
    所以在材质属性面板上,我们希望允许增加自定义参数类别,或者可以增加既定的参数类别,比如模型类别属性面板的里的“部件代码”参数,希望材质也能添加类似的代码(比如自定义成本1,成本2,成本3,税率等),以使其更方便与制造业的ERP系统结合起来,无论如何,将ERP于BIM两大行业系统的集合将是一种趋势,但revit还缺少相关的支持,两个系统间能准确的建立关联的前提是必要有一个唯一的编码,就像身份证号码一样!渴望被改进
3 Comments
Google translate:
Material panel parameters are not enough
Perhaps Revit's method of calculating quantities of engineering is more biased toward model building. However, in practice, some scenes are based on material areas as the main accounting basis, such as interior decoration. So in the material properties panel, we want to allow the addition of custom parameter categories, or we can add a defined parameter category, such as the "part code" parameter in the model category properties panel. We hope that the material can also add similar code (such as custom Cost 1, cost 2, cost 3, tax rate, etc.) to make it more convenient to integrate with the manufacturing ERP system. In any case, the integration of ERP in BIM's two major industry systems will be a trend, but revit is still missing. Related support, the premise that the two systems can accurately establish the association is that there must be a unique code, just like the ID number! Desire to be improved
TOM`
……A wave of Google translation:
   The problem mentioned in this webpage is probably the same as what I want to say! I tested this method. Adding item parameters to a material is actually only for the current item, not the material itself. The added project parameters can only exist in the project or template. Once the project passes these parameters it disappears and it is not conducive to reuse. If you can add more fixed parameter information to the material. Material library can be packaged anywhere and even on Mars! The important point is that we hope that the material library can add some cost information that has been audited by the financial department (these cost dataMay come from ERP system). This is done to make it easier to generate an accurate budget list directly in the REVIT schedule. And reverse verification. No need to convert data to Excel. This is just as difficult as going through Mount Everest. I think Autodesk can help us not to cross Mount Everest
     这个网页中提到问题大概跟我想表达的一致!我测试过这种方法。为材质添加项目参数实际上只针对于当前项目,而不是这个材质本身。所添加的项目参数只能存在于项目中或者样板。一旦进行项目传递这些参数就消失了不利于重复利用。如果能给材质添加更多的固定参数信息。将可以把材质库打包运用到任何地方甚至火星上!重点是我们希望材质库能添加一些已经被财务部门审核过的成本信息(这些成本数据可能来自ERP系统)。这样做是为了更方便直接在REVIT 明细表中生成一张准确的预算清单。和逆向验证。不必再把数据转换到Excel。这简直就像要穿越珠穆朗玛峰一样艰难。我认为Autodesk可以帮助我们不必穿越珠穆朗玛峰
