It would be a very nice/useful feature to be able to tag elements that are in an assembly from within an assembly view where the tag would read the relative distance of that elements origin from the assembly origin.
Example, I edit the assembly and move the assembly origin to a spot like the bottom left most corner of the largest object in my assembly. I place a face based family within the assembly on the largest object and it is placed 2' right and 2' up from that bottom left most corner. I would then tag the face based element and it would have properties that record/read its position within the assembly so that the tag will read X: 2' Y: 2', or just (2',2') or some other format. That you could through type properties say which dimensions you want to show X, Y, or Z.
