Array like AutoCAD
Array like AutoCAD
Lots of ideas concerning arrays. Most of them can be wrapped up as: make array as in AutoCAD? I.e. with all the bells and whistles it has in AutoCAD .
7 Comments
ipselute
I don't know what you're talking about. care to elaborate for people who has long since abandoned AutoCAD to the relics of time and the museums?
I would echo sarsenault.  For those of us who don't know how the AutoCAD array functions, it would be helpful to describe how you wish the Revit array tool would function.  I for one think the array tool functions fairly well for what it is.  But that's not to say there is much room for improvement.
ipselute
I have to admit i have (much) more knowledge about how Autocad works than how Revit works. In Autocad (as in v.2018) there are 2 array commands :ARRAY and ARRAYCLASSIC. ARRAY works kind of parametric way, allowing dynamic resizing of the array elements (by stretching / using the blue grips), ARRAYCLASSIC works more manually, the array resizing being done in a dialog box. Both ARRAY commands allow a multi-axis generation of multiple array objects: by x-axis and by y-axis. E.g. 10 rows by 5 columns of objects. You can also do angled arrays (rotated arrays from the base angle 0.00) , polar arrays and even 3DARRAY (x numbers by y numbers by z numbers of objects). In Revit you can only do linear arrays of objects (by ONE axis only): first do 10 rows, then copy them 5 times to get an 10 by 5 array. In Autocad you can do it in one (single) step / command, in Revit you need 2 steps / commands (or even 3 steps, if you want something like a 3DARRAY). "Multiple copies" option in Revit is actually of some help, yet it doesn't allow multi-axis copies. ARRAY in Autocad is a matrix-like generation of objects, ARRAY in Revit is like childish replication of single object.
Simon_Weel
To complement ipselute: Array along a sketched path and, very important, the ability to rotate / not rotate the arrayed objects, like in a polar array.
ipselute
@Simon_Weel: i believe Revit can do "multiple copies" along a path, and even multiple "polar" copies along a circle or arc, but it cannot "generate" multiple rows of those copies. You have to offset the path manually, then copy the array source object to the new (offset-ed) path, then do a new array along the new path. Kinda tedious and repetitive. You can easily rotate the copies by selecting them individually, then pressing Spacebar multiple times for multiple rotated positions.
gimbertG44JQ
Community Visitor
make an array in any line, doesnt matter the shape
