Allow to enter HEX Color Code in the color palette.
Hi Team Autodesk,
Kindly provide an option to enter the Hex color code value in the color palette.
Which will save some time while we create materials.
@Anonymous
14 Comments
JavadHamidi
Realy... Why we don't have any colour code in colour selection pallet for a fast copy of colours...coping RGB  is an ancient way...
Tags (1)
elzohry2007
That's awesome
greate idea
we hope to see it
m-de-lange
Why it's still not added baffles me.
Filling in RGB Codes for materials is annoying as it is now.
We can manually fill in the RGB code and save that to the custom colors list. Fine, it works, sort of.
Ideal would be RGB color codes. Such as #FFFFFF, that we can copy and paste real quick anywhere at any time.
Whenever I want to use one of the colors from the web, I'll have to manually type in the  (000-000-000) code to get that color. This is not only extra work for no reason but also annoying.
If we could simply copy the code from such websites and paste it in the material browser to immediately get the right color, it would simplify the workflow by a lot. It would also prevent possible typo's that could cause confusion.
https://www.rapidtables.com/web/color/RGB_Color.html
Hi, @m-de-lange ,
Here are two similar Ideas that I would like to combine with yours:
Allow to enter HEX Color Code in the color palette. - Autodesk Community
COLOR PALLET - Autodesk Community
Thank you for your submission!
Kimberly
m-de-lange
Upvoted Both, thank you for the tip @kimberly_fuhrman-jones.
You're welcome, @m-de-lange ! I will combine all three to boost these posts!
-Kimberly
Radish_G
Thank you @kimberly_fuhrman-jones .
@Radish_G You're welcome! Happy to help!
-Kimberly
curtisridenour
Yes please
moyano_2047818
Community Visitor
how is it 2024 and this still is not a feature? why do we have to wait for such simple things.
bryceUT3KU
Agreed!
nathan_torggler
... would help some work, since you only need to define one value instead of RGB. For Material, line color etc.
estebanward
Found this, should help somewhat although why it is not in the program itself heaven only knows. You can create and save your own colour book using hex code.
Enjoy
https://download.autodesk.com/global/acb/index.html
nicholas_tsagkosDGMM2
That would be great, typing and remembering three numbers is slower than just copy paste one code !
Autodesk please incorporate this amazing idea. RGB is old fashioned way and time consuming, be in the position of a technician, listen to the users and learn from AutoCAD!
