cancelar
Mostrando los resultados de
Quiere decir:
Allow section view depth to be set to 0
In sections that are not parallel to the building’s geometry we get a lot of very short elevation lines which we had to turn invisible (even worse: individually! Also see https://forums.autodesk.com/t5/revit-ideas/linework-override-for-multiple-lines-at-the-same-time/idi... ) for graphical style purposes. To allow a view depth of actual 0 would get rid of elevation lines and we would not have to rework them which is a big time saver for large projects.
7 Comentarios
No aplicable
Have you tried setting view depth to 1mm. Line weights usually hide those weird lines. Although I'm finding more and more architects want to show columns behind (etc) regardless of view depth.
gmp-autodesk1
Can we have a proper -in the meaning of exact- design tool please? Introducing hundreds of short lines into a drawing is not only unnecessary but also contradicts the point of having a computer based design tool.
No aplicable
workarounds are not solutions.  this is a great idea.
danny.lewisA9QBW
In Autodesk Inventor, there's a checkbox button called 'slice' that makes a zero depth section.
... So Autodesk already knows how to do this, they're just too lazy/distracted to do it.
Mr.Borges
This is a must have when working on non strait geometry. The mess of lines generated by a only 0,5mm Far Clip Offset is a pain. Please make Slice view available.
Mr.Borges
Sometimes we really want that only geometry in touch with the section plane to generate boundary lines. As the Slice option in Autodesk Inventor.
Still no solution for this in 2024?
Enviar idea
