Revit should allow view annotations, particularly North Arrows, to be anchored to a corner of the Crop Region with a user-defined offset.
For example, a North Arrow could be set to remain 1/4" from the upper-right corner of the crop region. If the crop region is resized, moved, or its extents change, the North Arrow would automatically maintain its position relative to that corner.
Ideally, this could be controlled through View Templates so that plan views automatically receive consistently positioned North Arrows without requiring manual placement and adjustment on every view.
This could also be useful for other view-based annotations that need a consistent location relative to the drawing extents.
Suggested functionality:
Anchor annotation to Top Left, Top Right, Bottom Left, or Bottom Right of Crop Region
Adjustable X/Y offset
Annotation automatically follows changes to Crop Region
Compatible with View Templates
Works with North Arrows, Generic Annotations, and similar view annotations
This would significantly improve drawing consistency and reduce repetitive annotation work across large drawing sets. This would also provide an important visual orientation check. Plans are not always oriented with North toward the top of the sheet, and an automatically anchored North Arrow would make the actual orientation immediately apparent regardless of how the view is cropped or positioned. Because the annotation remains associated with the view rather than being manually positioned on the sheet, it would also reduce the risk of a North Arrow being omitted, misplaced, or becoming inconsistent when views are reorganized.
