All building elements to cut toposolids automatically
Never in history of the current universe have two object existed in the same place at the same time.
Also, earth never had higher priority than any building element.
Can we have this:
To automatically be this:
The same way it was with toposurface.
Including toposolids from linked files.
4 Comments
vblevin
Yes! This should be automatic.
Would save me time in cut profile and/or merge command(s)
aaronBWC
Agreed! Please make it so. [Though I would debate the theoretical quantum mechanics of two elements occupying the same space...it has not place in Revit.]
Mark_Engwirda
Indeed!
This idea has already been accepted so you are in luck 🙂
https://forums.autodesk.com/t5/revit-ideas/model-elements-automatically-cut-toposolid/idi-p/12007651
Now we are just waiting for it to happen, hopefully sooner than later.
mlteruel
Observer
Excavation in toposolids in Revit works quite well, although it is quite limited by the elements that are capable of creating an excavation. It would be necessary for foundation elements such as footings and beams to also be able to excavate, just like floors, roofs, and other toposolids. Ultimately, any element that requires excavation in order to be constructed should be selectable.
Tags (4)
