Adding arrowhead to a line
We need the ability to add any type of arrowhead to one or both sides of a line.
6 Comments
This is already possible using line-based detail items or annotation symbols (dual arrows).
I wouldn't want this for all lines as someone could do a select all and add an arrow to a start or finish and arrows would appear on all lines in a project.
lionel.kai
@Anonymous Do you need it to follow a curve? Otherwise, we also use a line-based Detail Component (with instance properties to turn on/off the "arrowheads" at each end) as @Anonymous suggests.
how to do it in detail item? I need to control the width of a leader line or add an arrow head to a line.
lionel.kai
New > Family
choose "Detail Item line based.rft"
draw line & arrow heads as desired (recommend controlling visibility with new "show start..." & "...end arrow" instance parameters)
drosenthalUQMVQ
it could be an instance parameter or a type parameter, no reason to be scared!
mknor
Observer
It should be possible to draw a leader line without a textbox, and it should work similarly to a detail line. Alternatively, there should be the possibility to add an arrowhead to a detail line as an instance choice, similar to how you would do it in any Adobe software.
