Add the possibility change the display size/color of the snap object in Revit
Currently, there is only one predefined way to display snap objects in Revit.
I would like to introduce the idea of having the possibility to change the size and color of the snap objects (mid-, center- end- points) for better visibility in the project.
3 Comments
Mark_Engwirda
I haven't had a problem with snaps, but I would like to bring up that when you are trying to dimension corners of objects if you need to dimensions something diagonally.
To even select the corner you have to cycle through using the tab key, only to see the highlighted corner point is infinitely small.
Can you see the highlighted corner selection in the screenshot, it is almost not visible.
 Why not make this corner selection more visible like a corner snap?
Some of the colour blind people I work with can't see the blue at all. This is an accessibility issue, not just nice-to-have preference.
Mark_Engwirda
Absolutely!
Forma Design Contest
