If you model a Spline through Points the orientation of the Spline varies. I placed the Diagnostic Tripod on different splines. For the adaptive Point I chose global z then hoxt xy. Its either the xz-plane or yz-plan which is perpendicular to the orientation of the line. All other Lines (circle, rectangle,...) always result in the same way see the images below.
This is a Problem if you host a Profile on a divided Path and want to create a form.
- It would be nice to get that fixed, so that the orientation is always the same
- And it would be great to have Button Reverse Line Orientation (It makes a difference if you draw from left to right or the other way round)
Orientation for Splines by Points
Orientation of Lines
