Able to change colour and size of press pull grips
Sometime depending on angle of a 3D view it is difficult to locate the press pull arrows to resize a 3D section Box, requiring you to rotate to find. Would be handy to be able to resize and colour these to users preference in the options menu, similar how you can specify AutoCAD grips(Colour and Size). Thus might help to more easily locate.
Other related examples might be the dot when controlling size of a crop window
Example Grips on a Wall Plan and 3D
11 Comments
NateBrush
Add an Option for users to customize grip colors. Pale blue circles for wire ends strain the eyes. Let users customize grip colors so they stick out from selections, pre-selections, and objects.
I submitted an idea similar to yours. Couldn't agree more. We need to have better graphics in this department:
https://forums.autodesk.com/t5/revit-ideas/clean-up-graphics-of-selected-elements-temporary-dimensio...
Sash
NateBrush
SashKaz's idea is much more complete than mine. Click the link and upvote his.
DMK™
Maybe changing colors for selection and pre-selection may help a little?Image 2823.jpg
It would be a helpful feature to enable users to customize the colours of different grips when they are active. For example, if you are have existing text that you want to move, rotate or stretch, you can move the mouse closer to those grips and they change from a blue to a purple. For me, this is hard to see if you have a lot of elements in one view and often another grip is inadvertantley activated. Even if the default colour is changed to red, or something that completely contrast blue, this would save time.
My idea (see earlier post) was archived. I have a feeling this one will be archived as well. To me, our ideas are so fundamental, they should be implemented into the core Revit product.
lucdoucet_msdl
An additional argument to encourage Autodesk to enable the customization of the UI colors, be they the selection grips or any other control, is color blindness in the blue-yellow spectrum.
https://en.wikipedia.org/wiki/Color_blindness#Blue-yellow_color_blindness
dplumb_BWBR
Nicholas.TsagkosDWHH6
Ross_MarshallATCSP
Community Visitor
Mini blue Grips while in a full MEP zone of a file file is nearly invisible and becomes a treasure hunt.
This really needs a custom setting.
csosa5DVL6
Community Visitor
The larger the screen resolution the smaller they are.
