Unregistered Version Eriziz's net reactor Pop up
6 REPLIES 6
Sujan.Maharjan
7177 Views, 6 Replies
Why am I getting this pop up error everytime I start Revit.
"Revit Lies in the tension between what we want to do and what can be done!"
6 REPLIES 6
in reply to: Sujan.Maharjan
Uninstall DotNetReactor....or stop trying to get into Revit's programming.
Sujan.Maharjan
I'm not sure what is DotNetReactor.?
Sujan.Maharjan
I still haven't found solution for this. I cannot locate what should i uninstall. And where did this Eriziz's reactor came from?
DotNetReactor is a way of securing a program so that someone can not open the code.
So the only way of finding out what program/add-in it is, is to remove all add-ins from your Revit add-ins folder and then add them back in one by one until that error pops up again.
loboarch
This is not a Revit related error. It is being caused by something else that was installed to the PC (typically tools used to "crack" software protections).  I would suggest doing a system restore on your PC to a point in time when you were not seeing the error.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Sujan.Maharjan
Thanks. I moved all the Addins in Programdata/Autodesk/Addin to another folder then the message popup didn't appear. I need to find out thich is causing the issue now 🙂
Forma Design Contest
Technology Administrators
