Unregistered Version Eriziz's net reactor Pop up
Sujan.Maharjan
Sujan.Maharjan
Why am I getting this pop up error everytime I start Revit.
"Revit Lies in the tension between what we want to do and what can be done!"
Uninstall DotNetReactor....or stop trying to get into Revit's programming.
Sujan.Maharjan
I'm not sure what is DotNetReactor.?
Sujan.Maharjan
I still haven't found solution for this. I cannot locate what should i uninstall. And where did this Eriziz's reactor came from?
DotNetReactor is a way of securing a program so that someone can not open the code.
So the only way of finding out what program/add-in it is, is to remove all add-ins from your Revit add-ins folder and then add them back in one by one until that error pops up again.
loboarch
This is not a Revit related error. It is being caused by something else that was installed to the PC (typically tools used to "crack" software protections).  I would suggest doing a system restore on your PC to a point in time when you were not seeing the error.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Sujan.Maharjan
Thanks. I moved all the Addins in Programdata/Autodesk/Addin to another folder then the message popup didn't appear. I need to find out thich is causing the issue now 🙂
