Trees and people not showing up!
11 REPLIES 11
Message 1 of 12
4222 Views, 11 Replies
I have downloaded Revit 2019 as a student, and although I can place both people and trees into the floor plan. In realistic/3D view- they only appear as boxes, and in renderings they do not show up at all.
I haven't ever had this problem before, I have tried uninstalling and re-installing but it did not work.
11 REPLIES 11
Message 2 of 12
joe_keogh
Hi @Anonymous
can you upload the Families her so I can test them?  Cheers
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Message 3 of 12
Message 4 of 12
ennujozlagam
have you tried to change your detail level to FINE and see if helps. thanks
Message 5 of 12
in reply to: barthbradley
Hi thank you, I tried it but it did not work 😕
Message 6 of 12
in reply to: ennujozlagam
I did try that but it doesn't make a difference
Message 7 of 12
in reply to: joe_keogh
How do I upload it as a family on this forum?
Message 8 of 12
Ah, I just went through this.  Don't know if your situation is the same as mine was, but let me first ask if you have the RPC folder installed properly. It's located here: C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2020\assetlibrary_base.fbm\RPCs.  See it? Does it have content?
Message 9 of 12
ennujozlagam
share your file here so we can check. thanks
Message 10 of 12
elias_munoz_neyra
I Have a similar problem. When the trees are taller than 3 m they disappear.
Can someone give me a hand with this one?
Message 11 of 12
Looks like a Phasing issue.
…"When the trees are taller than 3 m they disappear"?  Do you have a Filter to "weed" them out of the View when they get to tall?
Message 12 of 12
I just solved it by rising the height of the section box. I was cutting it somewhere below the top of the tree
Forma Design Contest
Technology Administrators
