Spots are not in level with the false ceiling
8 REPLIES 8
Message 1 of 9
346 Views, 8 Replies
Hello every one,
I'm having trouble placing the spots in level with the ceiling, Can you please help me to solve it .Untitled.jpg
8 REPLIES 8
Message 2 of 9
aRcHiTeCt.JM
... try this: .....in 3D click in a light spot and pick a new host .... then chose the ceiling
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 3 of 9
in reply to: aRcHiTeCt.JM
It worked thanks, it created a new spot referring to the ceiling level then I replaced them.
I've another question please
In the linked Arch model I had lighting fixtures so I deleted them and reloaded the model but seems like they still there so how can I delete them and why they still exist ?Untitled2.jpg
Message 4 of 9
aRcHiTeCt.JM
... go back to the model (before linking) and click in one of those lights, then with right click chose select all instances in entire project.... and click delete
... those doesn't look like ceiling hosted...
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 5 of 9
They don't appear in arch model so I can't select them , Sorry I am relatively new to Revit
Message 6 of 9
I found them in floor plan, So I deleted them ,, will check
Message 7 of 9
It was deleted , but I have another problem 😞
when I Render the spots don't show lights can you help me with that ?
Message 8 of 9
aRcHiTeCt.JM
... could be two scenarios:
1- you need to change the spot light family for another one (maybe that one is not working)
2- try  with these specs:
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 9 of 9
I choose these settings while Rendering ,
And I've replaced the spot so many time to find a working one, It rendered before
Forma Design Contest
Technology Administrators
