Exportinng to DWG and printing PDF - Parameters
4 ANTWORTEN 4
Nachricht 1 von 5
472 Aufrufe, 4 Antworten
I am wondering if Autodesk will develope Revit in order to export DWG and print PDF with the paramater the user want to choose to set the name of the file up.
The same Revit has (Long-Short)..., but with the parameter the file has.
I am talking just about Revit, no about external tools, Dynamo or API.
Tags (1)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
You can manage your DWG exports from the DWG Export/SElect export set up. in the set up window, you are able to change the layer names, colors, Lines, Patterns, Font, unit and so many other things.
Nachricht 3 von 5
Thank you for you comments, but it was not what I was requesting. I was requesting create the file with the naming convention that the client or the BS want. At this moment of time you can do it buying a Add-on, create a Macro or using a Dynamo (last option is the option I implemented in my company) but it is a real pity this function is not incorporate in Revit natively. Thanks
Nachricht 4 von 5
Yeah, x-rev transmit is an awesome tool....part of me wishes it was part of the program itself, but the other says it supports someone I know personally.
Guess could hold true to my wanting a built in pattern creator.
Nachricht 5 von 5
@Anonymous, could you please share the dynamo export acad/pdf. Thank you.
My email: ktsphandinhsu@gmail.com
Best regards.
Tags (1)
