Problem in uppdate
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
husamcivil
230 Aufrufe, 1 Antwort
Problem in uppdate
Hi all I have revit 2019 when I need to update  some content like Euro code steel profile
this error will display
attach. error massage
1 ANTWORT 1
Nachricht 2 von 2
aRcHiTeCt.JM
als Antwort auf: husamcivil
... sometimes with autodesk is like that... you have to try again for a couple of times..
.. or try to download the content of those codes and then install them
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
.. or maybe you have to allow the conection in your firewall
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
