Hello every one,
I'm having trouble placing the spots in level with the ceiling, Can you please help me to solve it .
Solved by aRcHiTeCt.JM. Go to Solution.
... try this: .....in 3D click in a light spot and pick a new host .... then chose the ceiling
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
It worked thanks, it created a new spot referring to the ceiling level then I replaced them.
I've another question please
In the linked Arch model I had lighting fixtures so I deleted them and reloaded the model but seems like they still there so how can I delete them and why they still exist ?
... go back to the model (before linking) and click in one of those lights, then with right click chose select all instances in entire project.... and click delete
... those doesn't look like ceiling hosted...
aRcHiTeCt.JM
REVIT EXPERT ELITE
They don't appear in arch model so I can't select them , Sorry I am relatively new to Revit
It was deleted , but I have another problem 😞
when I Render the spots don't show lights can you help me with that ?
... could be two scenarios:
1- you need to change the spot light family for another one (maybe that one is not working)
2- try with these specs:
aRcHiTeCt.JM
REVIT EXPERT ELITE
I choose these settings while Rendering ,
And I've replaced the spot so many time to find a working one, It rendered before
