Shortcut to place a specific predefined family
2 REPLIES 2
chughes
1029 Views, 2 Replies
Does Revit have the ability to define a shortcut that will place a specific family?
IE, I type 'NO' as the shortcut and an instance of the 'Internal Note' generic annotation family is pulled up and ready to be placed with a click of the mouse, just as if I had dragged the 'Internal Note' family over from the Project Browser to place it.
I did not see the ability to do so in the Keyboard Shortcuts dialogue.  It looks like it may be possible via Dynamo, but I haven't ventured down that rabbit hole yet.
2 REPLIES 2
L.Maas
in reply to: chughes
I do not think Dynamo is the solution for this. I believe Dynamo will not work with events, so catching keyboard shortcuts will not be possible. You would need to write an add-in to get this functionality
Louis
Please mention Revit version, especially when uploading Revit files.
Corsten.Au
"CS" Create similar is the closest you can get in Revit.
Just Keep a view, or library of all the families at one place in the project if possible,
and "Select the one you need" and Create similar.
Cheers
Corsten
Building Designer
Forma Design Contest
Technology Administrators
