Does Revit have the ability to define a shortcut that will place a specific family?
IE, I type 'NO' as the shortcut and an instance of the 'Internal Note' generic annotation family is pulled up and ready to be placed with a click of the mouse, just as if I had dragged the 'Internal Note' family over from the Project Browser to place it.
I did not see the ability to do so in the Keyboard Shortcuts dialogue. It looks like it may be possible via Dynamo, but I haven't ventured down that rabbit hole yet.
Solved by Corsten.Au. Go to Solution.
I do not think Dynamo is the solution for this. I believe Dynamo will not work with events, so catching keyboard shortcuts will not be possible. You would need to write an add-in to get this functionality
Louis
Please mention Revit version, especially when uploading Revit files.
"CS" Create similar is the closest you can get in Revit.
Just Keep a view, or library of all the families at one place in the project if possible,
and "Select the one you need" and Create similar.
Cheers
