Shadows not showing up when floor is drawn in
emilycross
Message 1 of 47
emilycross
I've been struggling to figure out why my shadows are only showing up outside the walls of this house, and I think I've narrowed it down to the floor. When I add a floor, the shadows cast by the interior walls are no longer visible. I'm a bit of a beginner at Revit, so I'm not sure what to try.
1. Floor is drawn at Level 2
2. Walls are drawn at Level 2
3. Shadows are set to be cast at Level 2
4. This happens on the floor plan view and the 3D view
I've attached images of flooring drawn, and one with it removed. It's also worth noting, we're working with Design Options in this project, though that doesn't seem to be affecting it, and I'm working in Revit 2021
Replies (46)
Message 21 of 47
@emilycross: change your Phase Filter to SHOW COMPLETE.
Message 22 of 47
@emilycross wrote:
What's wrong with what? I explained my issue in the original post.
Well, sometimes the explanation needs clarification.
Did changing the Phase Filter to "Show Complete" resolve the "issue" you were splaning?
Message 23 of 47
emilycross
No, it did not
Message 24 of 47
syman2000
I've looked at the file and shadow works when I placed a floor underneath. However I do notice some objects may project weird shadow like the door frame. It could be a shadow glitch which Autodesk may need to look at.
Message 25 of 47
Those shadows are coming from a masking region in Plan View of the Family
Message 26 of 47
Masking Region removed and replaced with Symbolic Lines in Door Family.
Message 27 of 47
emilycross
@syman2000
I hope this doesn't sound stupid, but how did you insert the floor when you added it? I'd like to try the same way you did.
Message 28 of 47
syman2000
I am using level 2 from your file. Draw a huge rectangle floor covering the entire building. When I project shadow on it, it works fine.
Message 29 of 47
I don't have any problem with Floor and Shadows either - just those silly shadows being cast by the Masking Regions in the Families. Maybe it's an issue with your Appearance Image. I don't have it to test. Can you post it?
Message 30 of 47
emilycross
I've attached the image below.
Message 31 of 47
Sorry. No effect.  It was a long-shot anyways.  If it had worked, I would have thought "WTF!"
Message 32 of 47
emilycross
Well thanks anyway!
Message 33 of 47
@emilycross: have you tried any other hardwood floor Asset fromRevit's  extensive OOTB collection?
Message 34 of 47
emilycross
Every floor I've tried has given me the same problem. I guess we just have to go with photoshop!
Message 35 of 47
Works here.  Turn off hardware acceleration see if it's a hardware related issue.
Message 36 of 47
syman2000
This is bizarre. When I duplicate the Level 2, the shadow offset. When I exit the view and go back to the same view, the shadow fix itself. Mystery deepens.
Message 37 of 47
What time of day is it?
Message 38 of 47
emilycross
I don't have a time of day set
Message 39 of 47
JM_K
Emily, I can't replicate the issue in Revit. Can I ask you to check that you have Revit updated to 2021.1 if you haven't already. It might not fix the issue but it's always a good idea to keep things patched to the latest version.
Insert witty comment here.
Message 40 of 47
hmunsell
when was the last time you Shut Down your computer? not just closed the laptop or did a restart, but actually Shut Down your PC and then turned it back on?
Howard Munsell
