Unable to open the revit model but everyone else on the team can
Message 1 of 8
As of last Friday, I have been unable to open the revit model.  But everyone else on the team can.
When attempting to open the file, the open sequence will stop at 64% and then I end up having to close the program through the task manager.
I have already deleted my local and try to reopen, rebooted my station, and attempt to open an earlier version of the file.  I have been able to open an earlier version of the model and I have also been able to open others files.
Any suggestions?
Replies (7)
Message 2 of 8
RobDraw
Try to eliminate all possible causes.
Start by making a detached version saved to your desktop. If it opens, it's most likely a network connection issue.
Rob
Message 3 of 8
SteveKStafford
If your model is hosted on BIM 360 you can try clearing your cache.
Also I find that I can usually open a model if I close all worksets using the Specify option in the Open dialog. Afterward I can open the worksets. Quite often this process reveals that there is a problem with a linked model and the opening sequence is delayed significantly because of the linked file.
Steve Stafford
Message 4 of 8
Lance.Coffey
Autodesk Support
Autodesk Support
If the local copy of the model will not open, here are some other items to test:
If the info above does not lead to a solution, could you post a copy of the journal recorded when opening the model?
Lance Coffey
Technical Support Specialist
Message 5 of 8
This model is not on BIM360 ... and I was unable to get the Open Workset dialogue box to open ... but we found that through the workshare monitor that it showed that i was in the model 14 times
Message 6 of 8
RobDraw
I've seen the worksharing redundancy. That's a network issue. There's some sort of instability happening.
Rob
Message 7 of 8
Our IT fixed it … it ended up being a windows update mishap
Message 8 of 8
shayesBBP4T
What did you do to resolve this issue ? I seem to be having the same problem.
