Need to set an hatch to a customized family
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
694 Aufrufe, 2 Antworten
Good evening to everybody,
I created a family in model place and in the top view i would like to visualize that with an hatch section...
I can I do.
thanks,
Giovanni
Beschriftungen (4)
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: Anonymous
You can create filter and add comments as your parameter
Change the cut and surface pattern to hatch
When you add the word "HATCH" to the comments, the object will have pattern on it.
Nachricht 3 von 3
syman2000
Alternatively, you can add inplace family material. First you edit the family.
Click on the material and map it to structural material
When you finish, you can add material and it will show up as cut material
