Rotating the entire project
4 REPLIES 4
amirhossein.jafarii
431 Views, 4 Replies
I should rotate the whole thing 180 degrees.
changing elevation labels will be a bit confusing.
I appreciate if you can help me.
Thank you,
Amir
Tags (1)
Labels (2)
4 REPLIES 4
Have you tried Rotate Project north?
On the Manage Tabb >> Position >> Rotate Project North Then choose the desired option
Take a look at "Rotate True North" and "Rotate Project North". Manage Tab>Project Location.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
That worked thank you!
Forma Design Contest
Technology Administrators
