I should rotate the whole thing 180 degrees.
changing elevation labels will be a bit confusing.
I appreciate if you can help me.
Thank you,
Amir
Solved by BDMackey. Go to Solution.
Solved by syman2000. Go to Solution.
Have you tried Rotate Project north?
On the Manage Tabb >> Position >> Rotate Project North Then choose the desired option
Take a look at "Rotate True North" and "Rotate Project North". Manage Tab>Project Location.
