I'm modifying a tag label, but this applies to all families.
How do I save/load family tag label Types - essentially fonts of a certain size.
How would I do this for text as well. I'm guessing it's pretty much the same.
Be nice if there was an intuitive way to do this - like dragging in a txt from a different file.
Anyway I just want to do this once and I'm guessing then there's a way to save/load this in as a library of tag labels?
How? And how could I load these things automatically, so that everytime I go into a family I have all text options available. It's ****ing frustrating to have to make text types/lable types etc... over and over again every ****ing family.
A lot of annotations come from the Revit Template ( .rte) and Family Templates ( .rft) that was used when you began your project, or when starting a new project. Do you know which Template you are using?
It does take a lot of work to set up a custom Revit Project Template. But once it's done you have gained a huge amount of efficiency on subsequent projects. Same for Families. Takes time to create/customize them, but once you have done it you can load them into your next project and gain the benefits.
