Revit wall hatch make mess while insert column
7 REPLIES 7
Message 1 of 8
ashf_4uSJRKF
435 Views, 7 Replies
Revit wall's hatch make mess while insert column and join.... it make me big trouble....  after column and wall make join .. please give some suggestion ....
7 REPLIES 7
Message 2 of 8
ennujozlagam
in reply to: ashf_4uSJRKF
try to edit your column family > then go to properties > uncheck automatically joins geometry to walls > load again and change the existing column with new one and see if helps. thanks
Message 3 of 8
RDAOU
@ashf_4uSJRKF
How about you post an image showing the kind of mess you are having
Message 4 of 8
ashf_4uSJRKF
in reply to: RDAOU
screen shot uploaded
Message 5 of 8
RDAOU
@ashf_4uSJRKF
Nothing attached...if you are using Windows 8 or Later
  1. use SHIFT + WIN Key + S
  2. Capture the screen
  3. Then in your reply use CTRL+V
Message 6 of 8
Sounds like you are describing a join order thing.  Switch the switch join order between the column and wall using the Switch Join Order tool.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-M...
...or Unjoin may get you to where you want to go.  If auto join is the culprit, you can turn it off in the Family.
Message 7 of 8
ashf_4uSJRKF
in reply to: RDAOU
image uploaded
Message 8 of 8
RDAOU
@ashf_4uSJRKF
It is a bug which Autodesk is/should be aware of considering the fact that it has been reported repeatedly since version 2018. It happens when the Join is in a wall set to wrap at inserts (window/door/opening).
If you edit wall type and set wrapping to <none> the join should work. However, to keep the wrapping, there are a couple of options/workarounds to Fix:
  • Option 1: (Easiest) is to split the walls at the column, then disallow join and use Join Geometry Manually and the join should work as expected (See GIF below)
  • Option 2: (Not as easy) is to edit the family of the inserts and fix the Closure Planes for interior exterior (there is a previous post on this option I will try to dig it up)
Forma Design Contest
Technology Administrators
