how do I set my wall heights to a floor default? I keep having to adjust it after its drawn.
2 REPLIES 2
svalen
228 Views, 2 Replies
My first floor walls are not set to extend to the second floor which is what I want.  I can't seem to figure out how to make this a default for first floor walls as opposed to changing the wall after.
Also, is there a way to draw in existing phase without having to adjust walls from new construction?
2 REPLIES 2
ennujozlagam
in reply to: svalen
set your base constraint and top constraint of your wall? thanks
in reply to: svalen
Options Bar settings are the Defaults.
Every Wall drawn will adhere to those settings - until you change them.
Forma Design Contest
