My first floor walls are not set to extend to the second floor which is what I want. I can't seem to figure out how to make this a default for first floor walls as opposed to changing the wall after.
Also, is there a way to draw in existing phase without having to adjust walls from new construction?
Solved by barthbradley. Go to Solution.
set your base constraint and top constraint of your wall? thanks
Options Bar settings are the Defaults.
Every Wall drawn will adhere to those settings - until you change them.
