FILLED REGION MARK
FILLED REGION MARK
hliS658H
Message 1 of 9
FILLED REGION MARK
hliS658H
I created a filled region and input info in Mark. when I copy the filled region, the mark information can't be copied. Is it a way to do it?
Replies (8)
Message 2 of 9
constantin.stroescu
because you used an Instance Mark not a Type Mark . In order to use  Type Mark , open Edit Type
Constantin Stroescu
Message 3 of 9
constantin.stroescu
Constantin Stroescu
Message 4 of 9
Comments will copy.
Message 5 of 9
hliS658H
The instance mark is for tag.  I created a tag family for filled region in order to tag the area and the region name. If I use Type Mark, then all the regions will have the same name.
Message 6 of 9
hliS658H
Thanks barthbradley!
Message 7 of 9
hliS658H
But do you know why COMMENTS can be copied and MARK can not?
Message 8 of 9
Marks have a special intelligence. Try making Windows with the same Mark.  You'll get a "Duplicate" error.
Message 9 of 9
hliS658H
Yes I noticed that. When I put same mark for different region type, the system prompted "duplicate value"
