Revit wall's hatch make mess while insert column and join.... it make me big trouble.... after column and wall make join .. please give some suggestion ....
try to edit your column family > then go to properties > uncheck automatically joins geometry to walls > load again and change the existing column with new one and see if helps. thanks
How about you post an image showing the kind of mess you are having
Nothing attached...if you are using Windows 8 or Later
Sounds like you are describing a join order thing. Switch the switch join order between the column and wall using the Switch Join Order tool.
...or Unjoin may get you to where you want to go. If auto join is the culprit, you can turn it off in the Family.
It is a bug which Autodesk is/should be aware of considering the fact that it has been reported repeatedly since version 2018. It happens when the Join is in a wall set to wrap at inserts (window/door/opening).
If you edit wall type and set wrapping to <none> the join should work. However, to keep the wrapping, there are a couple of options/workarounds to Fix:
