Revit Sun Path Different Across Views
7 REPLIES 7
Message 1 of 8
omcsweeney
629 Views, 7 Replies
Has anyone ever had a problem where the sun path is correct in a plan view but not in a 3D view? I was modelling a home and when I was verifying the suns position I could not get the 3D view correct. It is for an extension so need to make sure the neighbors aren't losing too much light.
7 REPLIES 7
Message 2 of 8
RDAOU
in reply to: omcsweeney
@omcsweeney
When you enable sun path you are given 2 OPTIONS with a quite informative description...which are you using?
  1. All views to project location? in such case sun path in all views should match
  2. Relative to View?...well not much about that can be said path would be relative to view settings!
Message 3 of 8
omcsweeney
in reply to: RDAOU
Thanks for Replying!
I am using the top one, Specified location etc.
Message 4 of 8
RDAOU
@omcsweeney
If they are not aligned means they have been set per view, based on the sun settings you defined in each (as per image below..
To get them to match...you can use a view template ... with only Lighting Checked. Set the sun to the location you want and then apply to all view...after the views are aligned, remove the view template SEE GIF BELOW
  • Alternatively you can use dynamo to align just the sun path in all views (use package Ladybug and Genius Loci)
Message 5 of 8
Have you checked the box below?
Toan Nguyen
Message 6 of 8
omcsweeney
in reply to: ToanDN
Yes that is checked. I will dig deeper and see what could be causing this! Thank you for your response.
Message 7 of 8
omcsweeney
in reply to: RDAOU
I will try that and dig deeper and see what could be causing this! Thank you for your response.
Message 8 of 8
Maybe share some pictures showing how they are different.
Toan Nguyen
Forma Design Contest
Technology Administrators
