We have an area that is open ceiling and I want both ducts and structural elements show up in the ceiling plan in this area. I have both linked models check to be visible. The mechanical model shows up but the structural doesn't. Why the structural model elements don't show up in this view? Is this a view range issue?
Any help is appreciated
Solved by jvpantin2. Go to Solution.
Solved by syman2000. Go to Solution.
Check and see if your link model is set to fine.
Take a look at the Discipline parameter (Graphic group) in Properties palette. Structural or Coordination must be selected in order to show structural elements.
