I am trying to create a wall that would extrude to underneath the stair.
Any ideas?
Please see the attached file.
Solved by barthbradley. Go to Solution.
Edit profile the wall to match the bottom surfaces of the stair? If the bottom of the stair is a single slope then you can draw a ref plane and attach the top of the wall to it.
Toan Nguyen
Like this?
This is a bit challenging but doable if you have full Revit (not LT). My approach would be to add a Right Support to your Stairs. The "Right Lateral Offset" and "Width" and "Material" of the Support would match the Wall.
Then I would Attach the Wall Top to an In-Place Modeled Sweep (Category=Roof) that is pathed along the bottom of the Support. After attaching Wall to the In-Place Modeled Roof, I would hide the target roof in the views via Hide in View: By Element.
See the attached file.
