Wall under the stair
2 REPLIES 2
Stephm419
1602 Views, 2 Replies
I am trying to create a wall that would extrude to underneath the stair.
Any ideas?
Please see the attached file.
2 REPLIES 2
in reply to: Stephm419
Edit profile the wall to match the bottom surfaces of the stair?  If the bottom of the stair is a single slope then you can draw a ref plane and attach the top of the wall to it.
Toan Nguyen
Like this?
This is a bit challenging but doable if you have full Revit (not LT).  My approach would be to add a Right Support to your Stairs. The "Right Lateral Offset" and "Width" and "Material" of the Support would match the Wall.
Then I would Attach the Wall Top to an In-Place Modeled Sweep (Category=Roof) that is pathed along the bottom of the Support.  After attaching Wall to the In-Place Modeled Roof, I would hide the target roof in the views via Hide in View: By Element.
Curved Wall Under Stairs 3_A.pngCurved Wall Under Stairs 4.pngCurved Wall Under Stairs 5.pngCurved Wall Under Stairs 1.png
See the attached file.
Forma Design Contest
Technology Administrators
